It is currently Sat Jul 19, 2025 1:25 pm
 Post subject: Disaster strikes....
PostPosted: Sun Nov 22, 2020 8:26 pm
Posting a question about a new build one is working in the Instrument Restoration and Repair forum is not a good thing! A small disaster stuck today. Apparently I didn't crank my vice down tight enough when I put the neck in it to let the finish dry and it fell out. Of course it landed right on the finger board extension and broke it off in a rather nasty way.
oops_sign
Two questions for the collective knowledge around here.
1) Is this worth trying to save or should l remove it and make a new fretboard? The fretboard is ebony with ebony binding and maple perfling. I hate the idea of starting over as its got some nice inlays and, more importantly, a tricky end that matches the sound hole. But if its not going to be stable after fixing it I would rather replace it now rather than have to deal with it later.
2) Assuming its worth fixing rather than replacing, what's the best way to glue this up? I am thinking black epoxy.
Carl.
 Post subject: Re: Disaster strikes....
PostPosted: Sun Nov 22, 2020 8:40 pm
I'd use a brown hide glue, but if you don't use that try black super glue from StewMac.
PostPosted: Sun Nov 22, 2020 9:18 pm
Try to glue it. If you don't like it then make a new one.
PostPosted: Mon Nov 23, 2020 10:48 am
Titebond would be fine. It should glue up well because the break runs along the grain.
PostPosted: Mon Nov 23, 2020 3:01 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I did that once! Titebond or CA will work. You can hide nearly any repair on ebony. Lots of surface area for a good glue joint.
PostPosted: Tue Nov 24, 2020 10:56 am
Yup, just fix it. Glue it and clamp it then clean it up. Ebony is very forgiving.
PostPosted: Sat Nov 28, 2020 8:59 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Definitely fixable.
